Return issue
BG1988
bought a set of cables the quality is not great on the
ether
A. got the same set back
B. another reject set of cable
C. you have gotten a bad shipment of cables
it should all be facing the same direction per the manufactures specs..
wjburken
Eastern Iowa
RockAuto and/or AC Delco don’t owe you anything other than maybe a new set of wires. Their warranty, and pretty much any other manufacturer’s warranty, specifically states that they are not responsible for consequential damages.
http://www.rockauto.com/genImages/301/ACDelcoQuickRefGuideApril2018_2.pdf
Besides, I’m confused as hell. In this post you are blaming everything on a bad set of plug wires that should have been looked at prior to installation and not installed if there was any question. In your other post, you’re talking about taking the shop that installed them to court. Who bought the plugs? Who installed them? You’re all over the place on this and trying to blame everyone else and not taking any responsibility on yourself at all. You have a 12 year old vehicle that has multiple issues documented here with low oil levels, bad MAP sensors that cause unexpected acceleration and other issues and failed cats are not unexpected at the age of your vehicle.
MyCleftNut
