avalonandl
Usually the bolt on the body, not the one on the frame.Mine's fine too, just hit 118k.
Where do they usually break at?![]()
Yessir. Might be the cat itself though. You can swap the downstream sensors and see if the code follows. If it doesn’t then it’s the cat.
This one? I'm not seeing any others.Usually the bolt on the body, not the one on the frame.
Uh, self tapping bolts from front splash shield?Going to the pick a part tomorrow. They have 2 yukon's and one Esky truck........anyone need anything reasonably sized for easy shipping?
I'll check back in the morning when I hit the yard.
That’s the spot that was broke on mine.This one? I'm not seeing any others.![]()
Yep no support and flaps in the wind.This one? I'm not seeing any others.![]()
Just like saggy boobs. Just sayin'Yep no support and flaps in the wind.
What's the reasoning behind the neoprene washers under the skid plate? I'd be worried that they would eventually deteriorate from the elements and cause the plate to rattle, or cause the bolts to loosen and leave the skid plate hanging down?Added the front diff skid plate.
Used these washers between the plate and frame just because.
If the two steering wheel accents silver on any of those trucks intact and not worn out or scratched as well as the window switch plates. Let me know what you get. Mine are worn out on the wheel and both from window switch plates.Going to the pick a part tomorrow. They have 2 yukon's and one Esky truck........anyone need anything reasonably sized for easy shipping?
It’s just personal preference. I like the idea of having something between the plate & frame. I’m under there often enough doing regular maintenance to keep an eye on it. I did the same on my 2015 with no issues.What's the reasoning behind the neoprene washers under the skid plate? I'd be worried that they would eventually deteriorate from the elements and cause the plate to rattle, or cause the bolts to loosen and leave the skid plate hanging down?
I have a brand new front passenger switch bezel in brushed metal if that’s one of the ones you need.If the two steering wheel accents silver on any of those trucks intact and not worn out or scratched as well as the window switch plates. Let me know what you get. Mine are worn out on the wheel and both from window switch plates.
I’ll double check it out tomorrow but yes these and the wheel pieces in the same finish.I have a brand new front passenger switch bezel in brushed metal if that’s one of the ones you need.
Nice pics of your masterpiece Mark. [emoji106][emoji631]I took some abandoned shopping center pics of The Machine today. I swear there were ghosts there.View attachment 253955View attachment 253956View attachment 253957 View attachment 253958
Just stopped at Cabellas in Hamburg. Used 1/2 tank of gas from Harrisburg! Gonna grab lunch calm down a bit maybe look at a new hand cannon at Cabellas and finish my ride back home using another 1/2 tank of gas!
Bank 2 sensor 2. Is... passenger side post cat?
