LED Bulb Recommendations
NJ Metsfan77
New Jersey
IncisionID
Did you use the same lights you said you were going to use in the first post? I'm looking to do the exact same thing on mine and I think your truck came out excellent. Did you use blue or super white for your bulbs? How do you feel the reverse lights work? They look good, but are they as bright as the stock OEM bulbs? Also, Did you try the vanity mirror LED bulbs? Thanks for any help on this.
I
IncisionInd
Hey sorry that it took me so long to get back however it has been HECTIC
raidernationmike: Naw i didnt witch out the vanity bulbs. The only person that uses that thing is the GF and she says their fine :)
Scotto2323: Thanks for the complements
NJ Metsfan77: Yep i used the exact ones that i listed in the first post. I used the super white as i felt that the blue wouldnt be the look that i was looking for. I feel like the reverse lights look great and they put out AT LEAST the same amount of light if not a little bit more.
Scotto2323
NJ
IncisionInd: Do your bulbs flicker the end when they dim out. (when you turn the key on, and the interior lights turn off)
raidernationmike
Redondo Beach, CA
@scotto2323: i just installed the same setup including vanity LEDs and puddle lamps. mine dont flicker.. they just shut off when (when it's supposed to dim out)
I
IncisionInd
Mine when it fades out go all the way to very dim flick once and turn off.
Scotto2323
NJ
Mine flicker once at the end too, wish they didn't though. I had old festoon bulbs with like 9 small leds in inside the single tube that faded all the way, but they died so that does not say much.
Conor
"Bob's your Uncle"
Seattle, WA
^ Yeah, LED reverse lights do not provide adequate lighting.
I have to disagree, I have had LED reverse lights in a number of vehicles and I was always impressed with the brightness and the look. They are much brighter than OEM, but not as bright as HID obviously.
Seth
- Putco has nice interior ones but I am not paying $250 for 6 lights.
I pulled the trigger on these lights from Putco and they are far and away the best LED's Ive ever used. The price is extreme and I wouldnt have bought them if I wasnt a dealer for them. I had the Recon LED's in my Silverado and they were nice, but the Putco's are better.
Fast55
Ventura County USA
The Putco set is great, but you can get very high quality LED's from V-LED's for less. High quality LED's are still high dollar though. I have no flicker with their bulbs.
RobK
