DenaliReyes
Detroit, MI
Try removing it and reinstalling it. Like I said sometimes it’s the mirror, sometimes it’s not snapped all the way in, so check your work.
I did, right after I installed them.i checked and made sure all teeth were in place. Moved the heater wires out of the way. I think the pressure of the ring that holds it in place is too much and bends it. I dont think its glass.
Bombsquad85
Northern VA
@BG1988 @Rocket Man @iamdub
Thanks for the help. I got that new MAF and the truck feels 100% stronger. Did some pulls getting on the the highway last night and she felt real strong.
I also picked up one of those Bluetooth obd2 scanners and the torque app and all readings are good. Before this MAF the reading was stuck at 1.6 g/s.
Awesome, glad it’s working out.
Saw these. Thought someone might be into them.
@05Single ?
DenaliReyes
Detroit, MI
Knock sensors plus connectors
Spark plugs and wires
Oil pan gasket
Oil drain plug
Valve cover gasket and grommets
Valley pan gasket
4 post cooling line gasket
Rear differential cover plus gasket
Ball joints upper and lower
Intake manifold gasket
Its going to be a fun weekend.
NjA4207
