h2100
Hello All,
My 2010 'hoe is not blowing cold air and the AC Snowlake flashes three times when it is activated. I tried a trick I read where you try to reset something by pressing the recirculate air button and the snowflake at the same time for 10 seconds. It did not fix the issue.
A bit more googling pointed me towards the Ambient Air Temp Sensor. Seems to make sense as the AC should not work in the very cold and the light flashes the same way.
FYI, my outside temp reading seems to be working and accurate.
So, I ordered two sensors as I saw a video that say the previous model had two. They are not costly, $10 each.
Finally the question, how many do I have? Are they behind the passenger headlight and/or just in front of the radiator?
Any other ideas on why the AC may not be working?
