Sam Harris
Here you go guys. They're wired into the door light wires like Tony said. Bright as hell at night, they really light up the ground. I just bought a roll of cut-to-length LED strip lights. You just cut them to whatever length you need, and peel the rubber coating off at one end which exposes the soldering pads. I used heat shrink tube over where the wires connect to waterproof that part.
View attachment 243041 View attachment 243042 View attachment 243043 View attachment 243044 View attachment 243045
Nice. Damn they’re bright af!
eand28
Pennsylvania
But.... TODAY,..... I am gluing a fog lamp lens.. It fell off on my driveway yesterday after washing.
I was not going to use my hands , holding the lens for 4 hours for glue to cure, so I improvised.....
Paint stir sticks fit perfect, to press on it.
At LEAST the lens fell on my driveway !!
If I am not confident the seal is perfect, I will remove the fixture and put a bead of sealant around the outer edge.
View attachment 243019 View attachment 243020
I did something similar but pulled it off and used a couple clamps
ivin74
05 NBS Nali
Htown, Texas
Today I installed the cluster back after getting it rebuilt and adding new white leds, it looks pimp.
ivin74
05 NBS Nali
Htown, Texas
They don't seem to offer anything for the 02 Escalade cluster like mine.
Nope, 02 options are very limited as I found out a long time ago. I finally decided my Denali cluster looked better than the alternatives.
wildcatgoal
New:
- Pitman arm
- Idler arm
- Idler bracket
- Upper control arms
- Lower control arms
- Camber adjustment plates
- Camber adjustment guide pins (get the Moog ones, not Specialty Motor Products)
- Front and rear bump stops
- Inner and outer tie rods
- Driver's side wheel bearing/hub
- Front differential axle seals and bearings
- Replaced broken front axle shaft tube
- Fluids in everything but transmission
- Oil pan gasket and O-ring
- Spark plugs
- Spark plug wires
- Steering column bearing
- Steering upper intermediate shaft
- Shift lever boot
- Cabin air filter
- Pioneer 2DIN stereo
- Image Dynamics speakers
- Backup camera
- New key fobs
- Energy suspension torsion bar mounts
- Replaced roof antenna that was missing
- Upgraded alt to battery wire to fused 4AWG
- Replaced idler pulley bearing
- Adjusted parking brake
- Front rear brake pads
- Front rear brake hoses
- Variable power steering bypass
- Power steering fluid
- Added power steering filter
- Rebuilt steering box
- PCV
- Fuel filter (FFV)
- Rear pinion seal
- Serp belts
- Amplifier bypass harness
- Bilstein shocks (front)
Took me couple hours............
New:
- Pitman arm
- Idler arm
- Idler bracket
- Spark plugs
- Spark plug wires
- Shift lever boot
- Cabin air filter
- Backup camera
- New key fobs
- PCV
- Fuel filter (FFV)
- Rear pinion seal
- Serp belts
Couple hours lmao. Nice work.
Woned2004
