915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Fixed the ABS/Park light, turned out to be the left front abs sensor harness was damaged. Replaced with a new free oem sensor no more light. Feels real good not the see the light on the dash again, feels weird at times seeing it not there.
So this only lasted a week, trying to see if it is in fact the ebcm.
Scottydoggs
NJ
oh i will, as always. it still smells like a new car inside it , and its a 13.
ordered the new tc last night, hope to have it in a week or two. got a circle d triple disk 3200-3400 stall.
then i need to get a larger trans cooler installed then the tc can get put in. i need to take the front bumper off to get to the stock cooler, im not leaving that to the shop.
Should post up a vid of the outing ;) I love how it sounds.
Scottydoggs
NJ
ill see if i can talk my friend into taking a drive by vid. not sure if cam in car would let you hear it fully. its pretty quiet inside, it dont even drone or nothing. all the noise is out back.
TheAutumnWind
Need quick info if anyone can help me... Can I install 2002 GMC Yukon Denali Sport front and rear bumpers and D pillars onto a 2001 Chevy Tahoe LT with the tow hooks without much to do? I thought I read there's a way to unbolt the tow hooks or swing them backwards or remove them. Looks like the rear bumper is a straight fit.
Take 5 seconds to look under your hoe instead of posting... they unbolt.
CDNTAHOE
Edmonton,Alberta Canada
Just got done changing rear pads, right rear caliper bled the brakes and repaired wires in drivers side door for master door switch. Things left to do...... Intake gaskets, valve cover gaskets valley pan gasket oil pressure sending unit and screen and finally front axle seals. Thank goodness I get a discount at Napa. And all this is being done by my technician in my garage.
dszx13
Flushed the brake system today. Got a lead on high mile stock 5.3 to swap in. Comes with complete harness and pcm witch I can use when I swap the 6.0 into the rcsb. If it has good oil pressure I’ll buy it and go through it and install it.
Phoenix2k9
