Wylie_Tahoe
The "E" at the end of the part number? That's for "environmental". It's the newer design of ACDelco filters that are made of more environmentally-friendly components.
Thanks for letting me know im buying a filter endorsed by AOC :rolleyes:
In all seriousness, I recall there being info presence or absence of the valve, and I really did not pay attention given the orientation of the 5.3L filter. Teats on a bore IMO.
mountie
I dropped off my keys to me mechanic.... I'll be out of town for a week ( on a cruise).... He's changing out my transmission fluid,etc, brake fluid, test out my 4wd ( I haven't tried it yet - 1 1/2 years owning the Yukon XL).... Inspect / measure brakes.....
I tried to spend $500.00, but couldn't get close to it. ( Good shop / very fair prices)
lowpost99
Lowpost99
Atlanta, GA
Changed the oil and filter went full synthetic Castorol Edge 5w30 WalMart online p/u in store $15 per 5qt. Removed the starter looking for slow oil leak above it. Seems like its the pan leaking from about 4 bolts in front. Cleaned it all up, put leak dye in the crankcase and will recheck in a week.​
Sam Harris
First Blackstone analysis. A little too much iron in it, but I do a lot of city / stop - go driving, so sounds like that’s pretty well expected:
SnowDrifter
Sasquatch Country
After some curiosity on another thread, did some reading... And added some 2 stroke oil to my gas.
I ******* hate the fact that this works. It idles smoother, how I don't know. I cannot make heads or tails of it. I'd have a very weak misfire once every couple seconds that tended with the oxygen sensor voltage. It's gone. I ******* cannot even with this stuff......
HiHoeSilver
Away!
Chicago
Do tell....
SnowDrifter
Sasquatch Country
Do tell....
So this thread got me curious: https://www.tahoeyukonforum.com/threads/getting-8-5-mpg-need-help.102485/
Reading: http://www.ls1.com/forums/f48/been-testing-oil-91206/
Some anecdotal stuff here: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5214715
Info here: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3972472/2_stroke_oil_in_a_4stroke_engi
That's about all I got for now. Going to run it for a bit and see what happens. Will be peering down my spark plug holes in a few thousand miles to see how it looks. Can't comment on fuel economy, my driving as of late has been too sporadic. Too many different conditions and driving scenarios.
Will run a UOA on it too but tbh I still have another year and a half before that would be appropriate because of an oil pump replacement recently.
Sam Harris
Eh... running diesel.?
mattbta
Frisco, TX
When I run about 4oz of TC-W3 in the tank of mine, it definitely runs much smoother. Now that I've been running Costco gas (which my rig also seems to like better) I'm going to try the TC-W3 again and see what happens.
TheAutumnWind
In other words cheaper construction. Its paper and weaker adhesive IIRC. Edit I see now others have responded to this as well.
Sam Harris
I have that set on my Yukon. Im tinkering with the idea to make the top and the bottom set of LEDs light up together. Also adding a resistor to dim the parking lights a bit more
Nice. Do you like them? How long have you had them? Any problems?
ARogg619
I have the same set on mine as well. I really like them. The only issue I had during install was that I had to take the screw clips off the OEM tails and switch them onto the new tails bc the ones that came on the news tails just wouldn't grab.
Woned2004
