TIGHTEN FUEL CAP Message - Check Engine Light on
JochenWoern
JochenWoern
Sacramento, CA
Still having issues
Unfortunately, the CHECK ENGINE LIGHT came back on this morning. :-(
Guess I will have to go to the dealership, unless anyone else has any valuable input.
Thanks for the help.
CHECK ENGINE LIGHT never went off AFTER installaing the following:
- A new Gas Cap
- A new AC DELCO CANISTER PURGE SOLENOID VALVE, part #214-2149
I therefore went to the dealer, who says that the only thing left which could cause my issues is the following:
- Fuel tank pressure switch, GM Part # 16238399-31133.
Anyone else had this problem and can you possibly confirm that this is my issue?
Thanks in advance.
jshaw5
Did the fuel tank pressure switch fix the problem?
05YukonXL
South Carolina
Digging up this old thread to inquire ... did the Fuel Tank Pressure Sensor do the trick? I've done the fuel cap, evap canister and evap solenoid (blew out all the charcoal too), still getting check engine. Thanks.
ivin74
05 NBS Nali
Htown, Texas
Did you use oem parts? Autozone/aftermarket are junk.
Give it a shot, you got nothing to loose it's the last part that can cause that code. The bad thing is that you have to drop the gas tank to get to the sensor.
HiHoeSilver
Away!
Chicago
What code are you getting? You say evap solenoid. Did you do the vent valve down by the tank, the purge valve up in the engine bay, or both?
treehan77
TYF Fiend
Crestview, FL
The first EVAP canister solenoid i replaced (AC DELCO) was bad. It happens. Easy to bench test though with 12v power.
Juju14
