So you have a 2008 Hybrid. How many miles on it?
96k at the moment the problem started at 92k
I just pissed cause it was a malicious act... possibly even damaged the catalytic converter it burned a lot of oil (oil vapor/smoke blow by) I was not the only victim of the shop they screw another guy as well he lost all of the oil in his drive way ( mine happened in July (when the oil change was done)
the other person happened in Dec..
looks like out of Lazyness the person working was not doing his job.
The shop should issue a recall and call everyone to have their vehicle checked to make sure it was done right that had oil changes there
if i'm getting CELs for p0420 on both banks then it's leaking or making extra pollution gases
no EGR
the oil was burnt to a crisp black like it had 10k-15k miles on it
lost approximately 3 quarts low oil psi 40PSI (at 1500 rpm)
that might be with in spec but that is a variable per engine
so it was slurping up oil with air. the aeration is the problem as it does not lubricate as well as just oil..
so this one is normally 55-60PSI at RPM say i.e 1100rpm
Was that right after refueling?
Oh boy, that sounds like fun. Has a mouse taken a liking to your wiring harness?
yeah even stuck in Auto Stop
Went 0-23mph in 2.5seconds
in auto stop
GM lied it
CAN accelerate VERY FAST in auto stop Vid for proof
I think the programming corrupted at lest for the acceleration limit?... normally you can't Accelerate that fast with out turning the ICE on
the blue tint is from the lens protector so it does not get scratched in shipping i forgot to remove it
at 16 seconds you can hear the valves
with a slight knock that is what i hear every time i start it... not before last winter when i bought it at 84k or even at 90k when i had the oil changed, 92k is when a significant amount of oil was lost due to that shop you only have to drop to 4qt then damage can occur..
I changed it at 86k, 90k and 94.5k it's up for another oil change at 99k 4500 miles seems the ideal, then I will have all of it done at 100,000 service(coolant, tras,diff plugs and front brakes) this way everything is brand new fluids
I suspect at a minimum there is cam shaft and Drive shaft damage valve lifters and blah blah blah..
do you guys think it would be better to repair this engine (it does not seem to burn oil at the moment but it will because of what happened and the AFM has gone funky)
