Skid Plates for our GMT900s?
I've always wondered if anyone made a metal front skid plate, now I know :)
Thanks for posting the links for the skid plate.
Has anyone tried to "make an offer" on his eBay link?
Pricing is fair but, shipping is rather steep.
ya @Galante had him make one without the slots in it and he got a better price, you can always call him and ask he is in San diego and he has a regular website or shoot him a message on ebay
Geoffsfas10
St. Louis
ok, so here's picture time. Its been rainy and kinda gross here so the undercarriage isnt super clean but its good enough.
Here is the front metal skid plate, covering the front diff and offering protection from the hump of the oil pan
And here is the transfer case skid plate. It mounts slightly to an angle, which I find weird, but it covers the front drive portion of the case completely from underneath.
full
And again, these were mounted using a stock bolt run into all the holes to act as my tap, since they are self threading, and then installed with yellow zinc, grade 10.9 M10x1.5x25 bolts and washers from O Reilly's.
992dr
Eastern N.C.
Ahh good to know. I'll have to send him a message.
Thanks for the info
St. Louis
20200106_122936 by Geoff Anderson, on Flickr
20200106_122922 by Geoff Anderson, on Flickr
What's the part # for the front differential metal skid plate?
Also, does that transfer case skid plate only bolt down at the front? Does the rear attach to anything or just stick out there?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Geoffsfas10
St. Louis
2001 Yukon SLT
Front diff plate number is 20944322
Xfer case plate number is 20922755
The Xfer case only bolts down in that front position. Its also steel, and about as thick as the crossmember steel, i put my weight on it pulling from that backside ( which isnt much granted compared to the tahoe ) and it didnt budge, was able to rock the truck pulling on it
St. Louis
That t-case skid plate #20922755 shows as not fitting the Denali.
2001 Yukon SLT
BG1988
2001 Yukon SLT
as the hybrid I would like to add extra under body protection there seem to always be a lot of garbage on the road.
2001 Yukon SLT
Does that crossmember in the photo look like yours? GM even used that PN# on the 800s and they had different TCs but do not know off-hand if they used your Borg Warner back then. If it sticks down a little, you can bend the shield a little bit for clearance. I had a finger or two of clearance with the Magna Power TC.
St. Louis
Not sure, I haven't looked recently.
I know when entering either my vin or vehicle make/model on websites like gmpartsdirect it says it doesn't fit.
2001 Yukon SLT
Geoffsfas10
St. Louis
2001 Yukon SLT
They say it doesnt fit because its wasnt technically ever offered as an OEM option for the tahoe/yukon platform. It said the same thing for my tahoe, but its on there. The crossmemebers and underpinnings are all the same from the silverado since these are still body on frame SUVs.
St. Louis
Wow, which vendor is that? Still want to get the front one for mine.
Autonation Parts Center Phoenix, goes by seller Partscenterplus on ebay.
With my ebay bucks, only paid $12 something for one and $15 something for the other, guaranteed delivery by the 13th.
2001 Yukon SLT
Geoffsfas10
St. Louis
2001 Yukon SLT
Same people I got both mine from. :thumbsup:
Charlie207
LFOD, New Hampshire
Reviving this thread to confirm info before I fire the parts-cannon. These are the two pieces needed?
Front diff plate number is 20944322:
Xfer case plate number is 20922755:
Is there a non-plastic splash-guard/skid-plate that replaces the piece that connects from under the bumper to the front cross-member?
JohanZ
