Is that a little street sign green I see there??? LOL
I can't find a skid plate for my AWD 2008 Denali.
Any leads?
Not stock ones, but something cool. Ya know, something that says I vape, wear a flat billed hat and No Fear gear.
My 01 has the one from the factory that's under the oil pan and front differential, but it's made of thick/rigid plastic
just remnantsIs that a little street sign green I see there??? LOL
ya they made both plastic and aluminum ones, I had put the metal one on my 00 when I had it also. the metal are supposed to go on the z71 packages but my 18 Silverado z71 has a plastic one, apparently they only put the metal ones on the z71 suv's? so I found some new metal take off's from a Tahoe to put on it last night on ebay.Mine too but its cracked.
more then likely notthere is also a factory metal one out there for the new z71 trucks but not sure if it would fit the gmt900's or not, I saw a picture of one on another forum
I will find out soon enough I ordered one for the Silverado last nightmore then likely not
i can check the hybrid since it's lower it might have a "metal one"
you could mock something up with a big piece of cardboard and then use that as a frame to cut out some aluminum, might work for smoother air flow anywayI've been looking for some thing to put under the back of mine. Removing the spare tire it looks like the bumper would just act like a huge scoop at higher speeds. I figured I would probably have to make one starting with a wide rear diffuser for a hellcat or something. As flat as the rear bumper is a flat sheet of aluminum or abs could prob be used just to tie it all in and give it some support
ya sounds about right, just got to figure out a way to bend it, if you have a machine shop in town they can probably set you up once you have the measurements/angles needed.yea i mostly just want to add some support for the rear bumper in the middle but an entire pan shouldnt be hard to throw something together...its low enough it wouldnt really need to cosmetically be that nice. an angle at the front behind the rear axle a couple inches up as to not catch any air.
some 1/8" aluminum should be plenty? maybe find someone to add some ribbing to it if needed
$34 shipped to your door. https://www.ebay.com/itm/GM-OEM-Radiator-Core-Support-Skid-Plate-20944322/262982382079
Pics after they're installed is a board requirement!
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
