AC Relay Stuck ON
bigfootchiro
Largo, FL
Hey guys! Long time since I posted asking for advice. Just as the title says, my AC relay, per the scanner data, shows that the AC relay is being commanded ON at all times. No matter if I unplug all sensors, unplug relay switch in engine fuse box, swapped out blower resistor motor and all, played with climate controls, etc, it stays ON. I believe that’s what’s causing me from moving forward with the crank relearn process. Any ideas guys?
@swathdiver @east302
is it shorted? have you checked for voltage to the relay?
UmmScott
Omaha
Disconnect the HVAC control head and retest..
Problem goes away = bad control head
Thats an easy somewhat quick test.
If it still is being commanded on, gonna have to look at the wiring diagram. Can remember if its a power or ground side switched relay.
When does the clutch engage/come on? Is it on when the ignition is on? Or is there a delay after starting the truck and then it comes on?
There's 2 signals to watch for...
Ac command on signal and the actual ac output from The PCM.
If you have an AC request signal present then the PCM is going to activate the ac clutch relay.
Gotta figure out if there is a programming issue causing this or if its a hard fault in the PCM or even a crossed/shorted wire.
If your scan tool is saying there IS an AC request, then something electrically in a module is malfunctioning for some reason. If you have the HVAC control head unplugged then there shouldn't be an AC request at all im pretty sure of that
Sent from my SM-G975U using Tapatalk
bigfootchiro
bigfootchiro
Largo, FL
thanks for the reply! Yes, I disconnected the HVAC controls and still get the AC relay request ON. I can’t remember when it comes on. I want to say the compressor has a delay, then a click and it stays on. I even replaced the low pressure switch connector a while back.
UmmScott
Omaha
Ok...so thats a software thing..
If the relay were shorted, or the wiring was the problem it would be on immediately even when cranking the engine.
Since theres a delay, then that tells me that something is still giving an AC request.
The failsafe for most cars is to default airflow to the windshield and turn AC on.
Try disconnecting the high pressure safety or other pressure switch and see if you can do your crank relearn then
bigfootchiro
bigfootchiro
Largo, FL
I disconnected all relays and the compressor at once, and it still commanded ON. If it were on immediately on startup, we’re looking at short or bad wiring? I would check it, but it’s not in my driveway right now.
UmmScott
Omaha
In theory... if u had the pressure switches disconnected, no call for AC from the control head, had your power meter backprobed into the pin right on the PCM that provides either ground or power to the AC relay and you...indeed have either ground or power there...
Then that would be an internal issue with the PCM.
UmmScott
Omaha
Reason i say that..
Is disconnecting any AC pressure switch should kill any AC signal from the PCM regardless...
You could send that AC request signal all day long a million times and should not have the PCM command the relay on because its missing the inputs from the safety switches.
The way you're describing it sure sounds like the PCM is messed up somehow. Pressure switches disconnected but still having a command out to energize the AC clutch relay from the PCM = bad PCM. [emoji846][emoji106]
east302
Mississippi
Reason i say that..
Agreed. Removing the high pressure switch should kill the signal from the dash panel. Does it still show voltage on green/white wire (circuit 762) with the switch disconnected? I cannot remember which one that is... the one on the back of the compressor or the one on top at the hose manifold.
UmmScott
Omaha
Thanks east302!
So it is a ground side switched relay and the PCM grounds the coil internally.
Something is probably failed in the PCM somehow.
Woned2004
