Ideas
DGTAHOE03LT
Looking to put new wheels on tahoe. Looking to put newer stocks. Any ideas? I bought the Tahoe like this
Multnomah Falls
Military
The shy is the limit on wheel choices and can also depend on how you will drive the Tahoe. You have to live with them when you buy them so pick wisely. Lots of shock options for that 03 Tahoe. Someone here will chime in and again, depends on what kind of ride you are looking for. Plus, I think you made your first post in the wrong section. Welcome to the forum.
D
DGTAHOE03LT
D
DGTAHOE03LT
Yeah I’m new to the forum just trying to figure it all out. Thank you for the response
Nelson Camilo
Reason is looking for information about my Chevy Tahoe Z71 2002. Vin Z
I got a problem with the cooling system witch is leaving empty the coolant reservoir in a few miles but there is no leak,new reservoir ,new reservoir cap,no leaks notice,engine at idle and high speed running ok ,no misfire.NORMAL TEMPERATURE AT ALL TIMES OIL PRESS NORMAL
checking the floor of the garage no indication of coolant dexcool.
Every thing looks normal except the the coolant loos on the engine,
any information be appreciated.
wjburken
Eastern Iowa
Welcome to the forum Nelson.
How much coolant are you loosing and for how long has this been going on?
Why did you replace your reservoir and cap?
Do you smell coolant when you get out of the vehicle after driving it? Do you get hint of coolant smell inside your vehicle? Does your exhaust smell like coolant? Is your oil milky looking on the dipstick?
I would start by seeing if you can get your system pressure tested. If it loses pressure but you don’t see any fluid on the outside, you are probably losing fluid into your engine.
Nelson Camilo
Nelson Camilo
I already check the. heater on the inside , no smell, no coolant, also the pressure check on the engine was perform up to 17 psi and he drops to 15 psi and stay there , oil was change 2.months ago but no indication of contamination yet.
The reservoir was changed because to check the level was to hard to see, also the new reservoir comes with a brand new. Ac delco cap for 15 psi.
This problem I notice from several months ago, now is the point when is required to watch.
The consuption of coolan yesterday was a litre of coolant in 5 miles and on my way back nothing was lost.
No coolant odor by the exaust.
Willis12345
