Metallic Sound when Engine Running
tiktok4321
I have a strange metallic sound only when the engine is running. I don't have any issues with driving. Any thoughts on this?
It sounds like crumpled tin siding dragging under the car...
Unique to Hybrid? Common to ICE Tahoes?
Sent from my Pixel 2 XL using Tapatalk
Big Mama
Virginia
I’m no expert on hybrids but metal sounds are never good. Need more info. Any codes? Doesn’t do it in electric mode? Coming from where under the car? Sounds intensifies with speed? Oil level ok? No metal on dipstick?
Multnomah Falls
Military
Any loose heat shields?
Yea, first thing I thought of was the heat shield rattle possibility. Shields on exhaust and starter and anywhere else can be notorious for noises. Specifically the exhaust heat shields. Especially in areas that use salt on the roads.
Does it make a difference, at idle, if you are in gear or not? Maybe a flex plate rattle as well.
tiktok4321
tiktok4321
I'll check the heat shields. It only happens when the ICE is active, regardless of gear position.
tiktok4321
tiktok4321
I own a 2002 Tahoe. What is ICE?
Internal combustion enginee. Just a way of differentiating the hybrid propulsion system from the conventional engine.
Big Mama
Virginia
sound speeds up when you do? Can you force the ICE on while in park? If so still hear it?
