Odd question, and I ask because my truck didn't have the owners manual when I bought it. My 06 SD has auto dual zone HVAC. Is there a way that when you adjust the drivers side temp that it controls the passenger side too? I don't often have passengers in it, and in Colorado, in the morning you need full heat, but by afternoon you need almost full A/C... I get tired of having to set both sides. My 09 has a pass button that activates the dual zone separate temps.
Owners manuals are pretty cheap on EBay and you might learn about features you never knew your truck had.
Scottydoggs
NJ
i got one for all my cars/trucks on line pdf's that read just like the originals. only you can click on a chapter and bam,,,your there. the 13 camaro i have, the on line manual is 100% the same for sure. as well as the 05 tahoe. ive got the factory manuals, but reading em off the pc is nice cause you can make the print larger.
Fosscore
Crawling underneath the front end this weekend and noticed this.
Appears both sides are torn.
Suggestions on fix/replacement?
C6EE5D89-A0A0-4DE7-ACA4-9194180FA37A.jpeg 70BFA440-1637-45B2-978C-A83BFB17ABF1.jpeg C38C13AC-D5D8-4C3A-BDCF-E82268933ACD.jpeg
Sam Harris
Washed and detailed the exterior. That Chemical Guys tire and trim gel is the shit! Thanks @Adventuredenali92!
Fosscore
tie rods, there's bajillion of them out there, I would say oem or some higher end mevotech if they make them
Thx man. We are looking at the inner tie rod right?
Is it worth doing the inner and outer tie rod ends or just the inner for now? Or anything else at the same time for that matter?
I mean we could refresh the whole front end with one alignment, but may not have to if the other parts are still in good shape plus it is a bit of $$ to do it all at once.
Like this one from Moog?
https://www.moog-suspension-parts.com/moog-es3488
madmax442
