14RamHemiSport
- Joined
- May 21, 2019
- Posts
- 93
- Reaction score
- 44
I could very well be wrong as to which one, I still get twisted around and confused when I'm under there, don't like being upside down! LOL
But yes, that's about all there is to it. I would get the proper installation tool, they are less than $20, J45756 for your BW4485 (NR3).
Make sure the driveshaft goes back on to the exact same threads it came off of up front and in the rear, make some witness marks on either side before pulling.
I'm starting to get some weeping in a couple of places, TC, Rear Axle, etc. Not enough to worry about yet and in fact, we just changed the fluids down there and left those seals alone for now.
thank you for all that info. these gm trucks are new to me. for some reason, there isnt a lot of stuff on these 6.2 awd setups. plenty on 4wd yrucks. esp on youtube. for my ram there is basically a how to for every repair. if the rain stops im going to give it a better look over tonight. clean it up. ill probably pump her full of fluid just to make sure there is enough in there until i replace that seal.
i have read plenty about marking the drive shaft connector. i need to touch up some of the exterior paint, so that paint pen will work great.
thanks again for your help.
