Temp 3/4 way high, fan growling
treehan77
treehan77
TYF Fiend
Crestview, FL
Spent 2 mi it’s on the ramps and it made a good size puddle right away. I guess I’m glad it’s coming out onto the ground as opposed to “disappearing” into the motor. Is water pump the consensus? Couldn’t see it coming out anywhere while it was running, but it’s covered with dexcool everywhere.
8824A5A2-C695-40A9-BE2A-2FDF7D53A351.jpeg 47A56F15-E87E-4E99-A6B1-3057CCD38743.jpeg 9FCBA6D7-EADA-4BAB-A3C4-1E374A5AD139.jpeg
BG1988
thermostat not opening all the way, can cause it to run at 3/4 temp ..
Multnomah Falls
Military
Drips on the linkage looks like water pump leak and I would never ever change a water pump without doing the thermostat at the same time.
Easy job. Check the coolant crossover hoses under the throttle body, too.
Chris2144
Agreed can be done in an afternoon. Flush it clean it new pump and thermostat bleed it and you're good to go
treehan77
treehan77
TYF Fiend
Crestview, FL
Ok, for a 2005 Yukon 4.8, can anyone tell me which of these I Need-
ACDELCO 252845 or 251743?
anything else? Do I need a new housing or something?
Multnomah Falls
Military
I would use the 251743 Water Pump-AC Delco, 131156 Thermostat-AC Delco and the 35720 seal by Fel-Pro.
The AC Delco parts are OE equivalent and I love Fel Pro quality.
All available at Rock Auto
Because I am so OCD I would also run a nice clean tap in the mounting threaded holes to clean them out before reinstalling the mounting bolts.
I don't see that the water pump comes with the gasket/seal. Seal-Fel Pro #35633
Gasket-Fel Pro #35635 or AC Delco #251663
mitchievu
