2015 GMC Yukon LED DRL Problem
reath1
You and I both! The problem is everywhere. The solution...is only here. Definitely will do. Probably be trying it next week.
reath1
I haven't had a chance to tackle this yet but will soon. Question, to the best of your recollection, did the board appear to be "right" or "left" side only or did it appear that maybe it would work in either light? I know you only took one apart but what is your opinion?
brentcooper315
If I'm understanding this correctly then there is a board in both the driver and passenger side lights. I only did this fix on my passenger side but should work the same for the drivers side
reath1
What I was actually saying is, I'd like to buy a damaged headlight from Ebay that the LED strip is still functioning in to have n hand if my "fix" on mine doesn't work that I could swap the boards out. Just wondering if I buy a left headlight would the board be the same as the right headlight depending on which I may stumble on cheaper.
reath1
I actually ordered that for when I get ready to attempt this fix. Thanks.
adventurenali92
Big Bear Lake, ca
brentcooper315
I would assume they are the same but I'm not sure of that so don't quote me on that.
