intheburbs
Ok, interesting issue here, hoping someone has had this before. 2008 Suburban 2500, 6.0 LY6, 192k miles, stock except for Blackbear tune.
I don't drive this truck frequently, and when I do I always use remote start. Well, this morning, after driving a bit and stopping for a quick errand, I jumped in and tried to start using the key. Just got a click, as if the battery was dead. BTW, I have dual batteries, so it's unlikely I don't have enough juice/voltage. I took out the ignition key, opened and closed the driver door, then tried to remote start and it fires right up. Shut it off, try to start with they key - just the click and no start. I can insert the ignition key and turn it to run after remote starting and the engine stays on. I have no idea how long this situation might have existed.
Any thoughts? I'm going to start digging around and checking wiring, but this one has me perplexed. TIA
ETA: Is it possible that I'm on the ragged edge of sufficient voltage, and that the slight extra draw of the headlights/climate control/etc. when using the key is enough extra draw to cause a no-start?
Here's a video of the behavior:
