BG1988
well from what I have read the cat temps seem to be pretty normal, on the freeway they ran in the 1500's both of them dead even same temp no matter what it was, fuel trims seem to be normal, all 4 02 sensors seem to be normal also, so i'm stumped.
1500F degrees? your running rich
leaking fuel injector..
815C is passed the limit where damage can occur you can bet it will need replacement very soon..
it should be running 525C(Minimum operating temperature and meeting said parameters etc etc.)
other wise it will trigger P0420
650C is typical unless your towing 3.5k rpm and going up hills etc..then it could be higher
Yes both temps should be identical :2cents:
according to the interwebz 1200-1600 is normal under a load and there should not be any melting unless 2000 deg or more is reached.
I am thinking of getting a backpressure test anyway just to be sure, I don't really feel like getting under there myself in 100deg weather, I would imagine the muffler shop could do it on the rack for a reasonable price.
BG1988
according to the manufacture it's a 3 way catalytic converter..
https://www.open.edu/openlearn/scie...way-catalytic-converter/content-section-1.5.2
i'm going out on a long trip about hour and 1/2 i'll let you know the readings that should be about a baseline
kbuskill
NE. FL.
Mine normally run in the 13-1400° range while cruising around in town.... around 7-800° after idling for a while... if my memory serves me.
I guess it all depends on how hard you drive/accelerate... I'm not to ******* my old gal.
BG1988
wjburken
Eastern Iowa
I wish, o'l Gavin Newsom would have a baby cow if I did though
Kee Fuller
las vegas
Replaced the leatherish skin on my center console. Doesnt look bad, but i can tell its a cheap quailty off ebay.
Installed the cabin filter too. That was a pain in the ass. Sprayed the coils with coil cleaner and i dont think i got it all, but its cleaner than before.
Woodblocker55
New skins 10 ply snow and towing tires yes I will put them on myself that way yellow dot ends up by the stem . They are so stiff of sidewalls it's going take a cheeta blast to get them to seat ya on a 6.5 rim even. There full wrap nylon steel belt radials . Get this with stepped ribs on tread to keep rocks from pinching between face tread. And pinned for studs [emoji849][emoji15] ya total over kill. [emoji106][emoji41] Each tire can handle 3042 lbs . Tire manufacturer told me to just put the air in that's recommended for the vehicle. That's like 34 lbs they can handle 80 psi. Next project is air bags in back coils [emoji106]
Sent from my LGL84VL using Tapatalk
I wanna see those when you get them on!
Fosscore
Looking at the overflow tank cold on the NNBS and it hasn’t been driven this morning. Shows below the full line.
Do I need to fill it up to the line or leave it as is for expansion?
You can try to make it stay on the full cold line, mine won't unless I have it done on the machine at the dealer, but I'm going to try again as well
Fosscore
You can try to make it stay on the full cold line, mine won't unless I have it done on the machine at the dealer, but I'm to try again as well
So either way, we are close to where we need to be at cold temp then? It looks low, but not actually too low to be too concerned about is what you are saying?
