Just bought a 2007 Yukon XL Denali
brodown
As the title states, I am the new owner of this 168k mileage beast. It was a one owner truck, majority of work done by the dealer via carfax. The car runs great- no weird sounds or anything.
The oil pressure is a bit low, it will idle around 15-20 psi, and then rise to around 40 psi during driving, has not gone to zero- has no warning or CEL lights. I have been reading a LOT of posts about this and I will bring this up to my mechanic tomorrow when I get the truck looked over, and get all the fluids/filters replaced. I have noticed that it will "clunk" sometimes when slowing down, around 1st or second gear. When driving at slow speeds, the transmission will sometimes jump between 2-3, feels like it has trouble deciding which gear to go to, is this common?
I did call the dealer service department that did all the work on it over its life, and the technician who apparently worked primarily on the vehicle, told me that the engine had a spun bearing and would need a total engine replacement. I find this hard to believe because the truck runs GREAT! Tons of power, no "spun bearing sounds" based on youtube videos. Getting her checked out tomorrow so hopefully everything goes fine!
IMG_4518.JPG IMG_4543.jpg View attachment 229506 View attachment 229507
St. Louis
There's a screen under the oil pressure sensor that gets dirty/gunky and causes low pressure readings at idle.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
08HoeCD
Trans rebuild in your future.
Other than that, Mrs. Lincoln, how was the play?
Welcome, brodown!
Big Mama
Virginia
Congrats I have the same rig but not xl. If you hear the clunk coming from the back when you let off then pick up that’s usually the limited slip rear on these AWD rigs. Changing the fluid and ensuring you use the conditioner helps. Higher grade fluid like Amsoil is even better. If the carfax didn’t bring up the heated washer fluid recall do that too. There’s a fire hazard there. I bought mine at a dealer and they didn’t do it so I did and got $100 to boot. Good luck.
B
brodown
Thanks- I am hoping the dirty screen/oil pump pickup ring is the cause, and that will be that.. BUT, worse case scenario: what does a "spun bearing" sound like? I am assuming the engine would be behaving differently? Is there any indication of this besides oil pressure sitting where mine is?
08grey
Read up on oil pick up tube gasket.
Sent from my SM-G973U1 using Tapatalk
Welcome!! You and I have identical-looking trucks.
I wish you a long and happy union with the truck
B
brodown
Thanks, your truck looks great!
So the mechanic gave her a once over, told me that the truck looks great for its age. May have a small exhaust leak based on sound coming from engine, but nothing really to worry about. The engine was definitely taken out at one point and worked on, but he drove it and said it felt fine.
Let's hope this baby lasts!
thompsoj22
I just did the oil change on our 2008 yukon denali XL-1500 AWD and it has the fly weight limited slip design "no clutches". did they use more than one configueration?
To the OP, Congrats! you will love your new to you yukon. Ask the mech how he determined a spun bearing? does the oil pan appear to have been removed? worst case scenario you need a reman 6.2 longblock and down the road you go! Hang in there.
