'04 yukon denali front tire dragging
Cadyman68
hey guys, i have 2004 yukon denali and everytime i turn hard left my front right tire feels like its dragging or skipping. the front end on that side kinda jerks and jumps up and down. had it aligned not too long ago and everything suspension wise including the cv axle and hub bearing assemblies in the front are all brand new. does anyone have this problem and what fixed it? help please it's driving me crazy throughing parts at it and it not going away!!!
sounds like it might need a control arm, pitman arm, and/or tie rods a good front end shop can tell you for sure.
Super Moderator
Elev 5,280
Is it in 4x4, or is the front diff engaging in error?
i have already replaced all of those items
I would take it back to the shop that did the alignment then and see if it's correct, otherwise only thing I can think of is somehow the front differential is out of whack
Splorg
Huntingdon, Pennsylvania
Not sure how the AWD in these works, but I know the previous vehicles I've owned that were AWD, when put in a hard near-lock turn under power would skip a little and that was considered perfectly normal. My 1996 Jeep Grand Cherokee did this quite a bit on dry stuff, but it was full time 4WD. Not sure about the engineering differences.
I'd still want to get that checked out though, especially if it's NEW behavior and it didn't always skip a little in a steep turn. Feel free to completely disregard this as it's just my two cents. [emoji16]
Sent from my Pixel using Tapatalk
BigTommy83
Have you had the transfer case services recently and was the correct fluid used?
Willis12345
