Mobile electronics specialist at your service.
89Suburban
Bull in the china shop
SE PA
I wanna add a rear sub/subs box/amp to my stock Bose system 2007 Tahoe LT. Affordable, do it myself, add some kick in the ass, but not overkill. What do you recommend? Preferably something with grates on it so shit sliding around in the cargo area don't damage the cones.
greenhornet
Ontario,Canada
Could you tell me where the signal light flasher is located,so I can replace it? I listen for it and all I here is the ticking out of the drivers left speaker no other speaker makes a sound.Thanks.
if your 07 has the bose ANC (active noise cancellation) you will want to disable that if you add a separate subwoofer, it is pretty easy to do the wires are right under your cup holder
lol, join the crowd if it is a 07 plus there is no flasher, you can however turn the volume down in the DIC. the flasher in the 07 is built into the bcm.
Legitly_Lazy
Legitly_Lazy
Lake Charles, LA
im going to need year make and model and by flasher are to talking about flasher relay?
Aray1288
