Any GM a/c techs here?
grouch
I'm trying to get my a/c working on my 2000 Cadillac Escalade. It's an early model so it's more akin to a '99. I learned early on to get parts for a '99 as the late '00 models are more like the '01. I was trained in servicing automotive a/c systems but that was nearly 50 years ago so I'm familiar with the basics but maybe not the details.
I vacuumed the system before starting. I hot wired my safety switch so the compressor would engage. The label says it holds 40 ounces of refrigerant. I added 36 ounces plus maybe an ounce of UV dye to look for leaks if it doesn't hold. I'm getting 40 psi on the low side but nothing on the high side with proper gauge set. I suspect the valve on the high side charge port is bad and needs replaced. Input air temperature is 78 degrees and output is 52. So it's working.
The compressor is filthy and looks like it's been leaking. If I have to open the system, I plan to replace the orifice tube, compressor and receiver/dryer. I noticed one connection with frost on one side and not on the other. I'm assuming this is where the orifice tube is on this model. Anything else I need to replace besides those parts and the hgh side charge port connector?
96-2D-Hoe
Not a GM tech, and no idea if it's the same but on my OBS but my orifice tube is on the output connection of the condenser and is accessed from behind the lower passenger side headlight. I don't think the orifice tube is the 'expansion valve' and there must be some kind of expansion device inside the dryer. I'm guessing the orifice tube converts high pressure liquid to low pressure liquid as there is no noticeable temp difference on my 'liquid line' from the condenser after the tube. Yours may be different. You probably have an HT6 compressor that is also known as a 'belly leaker'. I also need the high side port replaced but mine doesn't close. Rock auto has the complete valve and all parts for pretty cheap.
Just took a quick look at the parts for a 2000 Escalade and they appear to be identical to my OBS Tahoe.
There's a couple pics I took recently in this post https://www.tahoeyukonforum.com/thr...tahoe-yukon-today.30709/page-625#post-1328939
grouch
grouch
Add a bunch of dirt and grease and your set up looks identical to mine. A supplier I used when I ran a shop is still in business and my account is still there. (35 years later. Prices have gone up though.)
dnt1010
Tennessee
High side valve "leak" is pretty typical on these but I have NEVER seen one that you cannot get a pressure reading from? I suspect that your hose end quick connector is not seating down properly on the high side service port? or the pin on your hose end quick connector is damaged in some way and not extending when the knob is turned? Lets do a quick check on your equipment and retest.
grouch
grouch
Pushing a small screwdriver into the Schrader valve should have released gas but it didn't do anything. My gauges are in good shape.
dnt1010
Tennessee
Only thing I can figure is some clown head used super glue or something to seal it and try to stop it from leaking???? That is bad news as you may find some other SURPRISES! Once you properly vacuum and recharge with the new service port in place, evaluate for leaks/performance etc. and we will have a basis to work off of. If you do not mind use the following to gather performance data. Sufficient run time for system to stabilize (5 to 10 minutes) Windows down / AC controls set to Maxand recirculate / blower set to high with all vents open and Engine RPM at 1500 Now please note Low and High side pressures + outside ambient temp and middle vent temp.
grouch
grouch
Update. I replaced the high side Schroeder valve and put some dye in the system. It worked for about 40 minutes and went dead. I found a leak on one of the lines going to the rear a/c coil. I got a block off kit off Fleabay and capped the two lines. Instead of 44 ounces of refrigerant, I put 30 ounces to account for the smaller volume of the system. The system is still hold pressure and working great. I still blow some onto the windshield but I can live with that. As for the high side port, I still don't get a reading but on my Impala and Dodge Ram, I do. Since this is mainly a winter vehicle, I'm not too worried about it. I do use it to tow during the summer so I can tow with no sweat. (Literally.) Normally, I'd repair the lines to the rear but at nearly $400 each on a 20 year old vehicle with 240K, well the law of diminishing returns kicks in.
I did replace the compressor, reciever/dryer and orifice tube while I was at it. No junk in the tube but leaks on the compressor so I replaced it before garbage got through the system.
Miami-Dade
Super Moderator
Try asking UMMScott in the 2000 tech section.
grouch
grouch
I've got it working now. Not quite fixed right but good enough.
Funny thing about the 2000 to 2007 section, I had people telling me I was in the wrong section. ?????
rs401
