No spark, no fuel, no start but will crank 95 2 door hoe, 5.7l, 4WD
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
Good morning everyone. Got a strange thing going on the Hoe. I was having trouble starting her for the past couple of weeks. One day she'd be fine and then two days later, no start. She will crank, she won't start. Started troubleshooting. The fuel pump kicks on. I have replaced the fuel pump relay, the coil, the cap & rotor (she ran the best ever after I did this and then she died and has stayed dead now). There is a new ignition switch in the truck. Checked for spark, no spark. No fuel is being dumped in the bowl and no pulsing on the injectors either. Replaced ICM, replaced oil pressure sensor after we did the fuel pump because that died too. So we check my PCM. Pulled it and started looking to see if there was any visible signs of damage, etc. I start to look for a replacement. The last four of the PCM in mine is BJYL, but when I go to search for that, it comes up for Silverados, not Tahoes. The last four that comes up for Tahoes is BJYK. Could this be the problem? It's always had a weird idle and hiccups when stopped at a light. The engine is brand new, dropped in a crate 5.7. Any help is greatly appreciated.
I had the EXACT problem in my 01 Express van. It had the vortec motor in it. It was driving me crazy. Turned out to be the pcm. I know you have it narrowed down to that also. I bought brand new/reman, which had to be programmed to my vin and vehicle--which I'm thinking you'd have to do also.
dkknaebel
dkknaebel
St. Petersburg, FL
Thanks for the response. I think the PCM died. Only other thing i can think maybe is the ignition lock cylinder. Mine is wore out, you can pull the key when it is in the start position. I'm going to double check my PCM number tonight and see what is out there.
I'm not familiar with that model but do suspect the computer as well. Use your VIN to identify the right computer. Did you ever get the AC going?
dkknaebel
dkknaebel
St. Petersburg, FL
No AC yet as I had other projects going on. Is there a website I can go to in order to verify my computer? Or is that a dealer thing?
dkknaebel
dkknaebel
St. Petersburg, FL
I checked all three sites but they don't specify whether it is the BJYK or BJYL for the PCM. If anyone can help with the VIN, PM me please.
I wouldn't think that would matter when you have the part numbers. The one listed under AC Delco Professional says you must move the prom from the old computer to the new.
Without knowing your VIN, I came up with these two:
16197427 and 218-11795
Do you know anyone with a Tech-2 over there? It would be nice to know what codes are being thrown or see what the computers are or aren't seeing.
dkknaebel
dkknaebel
St. Petersburg, FL
The 16197427 is the one I have in now. The hubby has an OBD1 scanner, we are going to hook up the laptop and see if we can get it to scan. I have the bastardized OBD1.5.
PG01
Up here to the right
So, she cranks but doesn’t start right now and you have no spark, but you just replaced the cap and rotor it started, ran, died and now it just cranks?
dkknaebel
dkknaebel
St. Petersburg, FL
That is it exactly. Monday she wouldn't start, would crank. Grabbed new cap and rotor, she fired up. Drove her to work and then the gym and home. That weird flutter/hiccup had gone away and I was like FINALLY! then Wednesday, no start just crank. Put in a new ICM, no start just crank. Put in a new coil, no start just crank. Tested for spark, no spark. Fuel pump runs but no fuel to the bowl, no pulse on injectors
dkknaebel
dkknaebel
St. Petersburg, FL
That's good, not a hard job, but it just sux getting under there and taking it out to exchange it.
Eh, that is Future Dawn's problem at the moment.
Can anyone recommend a software program that would read the DTC's? I have an OBD1 DLC but when we tried to pull codes with my husband's datamaster software, nothing came up
PG01
Iirc to set the timing you need to unplug a connector on the firewall somewhere,I don’t remember where or how many wires tho and not sure what year this changed, it bypasses the pcm, i guess in theory if you unplug the connector you should get spark and fuel because it is bypassing the pcm... that way you know pcm, or a wire to pcm is bad. I know bad grounds mess up pcms.....its been a long time though.
koomie98
