Burnout with Tahoe 5.3?
Taavi
Taavi
Tallinn, Estonia
I don't know if you could do this but it is just an idea, maybe disable the rear brakes somehow? and then just sit on the front brakes with the water trick to the rear tires?
My idea now is to add line lock to the rear breakline. So I could be on park or neutral, activate line lock and the reat brakes would be deactivated then. I would like to order the line lock from ebay, but the problem is that transport to Estonia costs almost double the price of the piece itself.
PG01
Up here to the right
Its a slick racer bud, bleach, transfluid or any liquid and youll be able to power brake it, no issues
Onebad1983
Resident Country Dumbass
Not really a burnout, but it was quite easy to spin the tires when it rained and I waited for the green light on an intersection. But the rear diff locked almost immediatelly and stopped the fun. The G80 might not be a best for this kind of fun as it locks up 100% after slippage is sensed.
Maybe the best way is to find a set of old and hardened tires (summer or all-weather type) and prepare few barrels of water. I have also heard that shifting into 1 turns off traction control, but I can't really tell.
I spin in D in the wet so I don't think so
drakon543
adding a cheap valve to cut off the pressure sent to the rear brakes would be a huge benefit for you and you wouldn't really need to go crazy. just adding something to do a brake stand on occasion i wouldn't go too crazy. another suggestion or question what tires do you have on your truck? if you want do be able to do a burnout pick up 2 spare rims and put some really poor quality tires on the back. some real bottom dollar no name tires. if you do go that route you can also buy the tires one or 2 width sizes less. less tire contact means less traction. also you can up your air pressure in your tire but before anyone rips me up for it ill add my word of caution now. im only suggesting a little higher as i dont want someone to get hurt. a little higher on the pressure will also lower your contact patch causing less traction allowing you to spin easier.
GSDunk
Even with traction control ON, my 2003 5.3 burns out pretty easily.... Even on dry asphalt.
Shouldn't all the healthy 5.3s do that?
wbhidalgo17
