NORCAL SS Kit info/tech on how to level the rear of a 2015 up GM SUV
400exr1
@400exr1
how low did you go?
are you sitting on the bump stops?
have you done the 'free travel mod'?
No free travel mod. Not necessary with my ride height. 2.5 in from bumpstops.
Spoke to Tony today. He is a busy man. He suggested shortening the rods. I went from just under 3.25 to 2.75 center to center.
At first it seemed worse, but now it appears to have fixed my issue. My best guess is my rods were so long that they were flopping around because not much thread was in each plastic end.
gat0r
DFW
^ good deal
i asked about the bumps stops... as i lowered mine about 2.25" & I am close to mine, but have had no issues yet.
GusSanchez300
Miami FL
Is this the same for the 4/6 drop that I got, when I got the kit the truck didn't have premium ride suspension but now it does
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
6 inch rear drop requires more work and cutting bracket off frame
Stratguy
I'm interested in leveling my '16 Tahoe 2WD LS. Based on this thread, I contacted Belltech, and they told me that they don't offer a 2" lowering kit for the rear. Did they discontinue this? If so, what is the next best option. A local shop is recommending McGaughy's, but I'm reading some poor reviews about their products.
Thoughts?
Thanks
GusSanchez300
Miami FL
Thoughts?
Thanks
Contract NORCAL SS hee will get you what you want
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i have the custom 5305 plus 1 coils that i can set up with a 1 inch spacer andworks great
CMil527
Old Bridge, NJ
What does the 2" level spring set up run for a '18 Yukon XL SLE 4wd which I assume has the standard suspension set up... Thanks in advance!
Kyle Robbins
Ordering my rear leveling kit for the wife's daily soon! Thanks Tony
Kyle Robbins
Just curious , say stock ride quality is rated 10/10. What would you rate yours with the 2" rear kit. Mine was just installed and honestly I'd give mine now a 6/10.... it changed the ride drastically. My wife isn't going to be happy as it's her daily. Looks killer tho, did I do something wrong or am I just getting old?
