8.25 IFS PS Carrier Bearing Part?
Matthew Jeschke
Sahuarita, Arizona
I'm going to pull the axle housing off the passenger side of my 2001 Z71 Tahoe (has All Time 4wd option). I am not sure which bearing to purchase to replace that. It's a little tricky to figure out for me at least.
I am looking for Timken bearing and seal. However, I'm not too excited about taking it apart to measure then order the part. I kind of want to get it done in one day :)
Thanks!
SnowDrifter
Washington. The desert side not the Starbucks side
Is this the outer bearing for your output shaft?
Mine is a selectable 2wd/4x4/4wd auto.
Part numbers were
Bearing: TIMKEN SCH208
Seal: TIMKEN 710475
A quick check seems to indicate part numbers are the same for 4wd and awd.
On the exploded diagram, it's part numbers 21 and 22
http://www.demandaam.com/resources/pdf/file-20150130095347.pdf
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
It sure is :) It is parts 21 & 22 in your diagram. If you were my neighbor I'd come over and give you a 6 pack o beer right now. Many thanks :)
It's the exact same diff as yours, as has the AUTO 4x4. Honestly, I'm a bit sorted about pulling it and rebuilding the whole thing. I'm only scared of changing the pinion bearings as it seems to require some tools I don't have (such as inch pound gauge and larger torque wrench).
That's awesome... are you in tucson?
Sent from my SM-G925V using Tapatalk
No, Florida it was a joke! But if you were nearby the offer stands! Those two torque wrenches are not that expensive. You can get Tekton's from Amazon Prime at a good price delivered in two days and they are of good quality.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Oh awesome i will look the tools up. This was the inch pound meter I was looking at... It's to make sure the crush bearing is set right on the pinion. They all seem to be $100+ which for a one time job makes me a bid sad lol
https://amzn.to/2xctfHe[/QUOTE]
Curious i have built motors, even a couple racecar chassises way back when. However nothing ever like a diff or transmission. Is this say a level 7 of 10 mechanic possible job?
I am just super nervous of breaking new ground in my skillset :/
This is what I had in mind:
https://www.amazon.com/EPAuto-4-Inc...d=1536888562&s=Automotive&sr=1-11&ref=sr_1_11
Well, I haven't rebuilt a front differential but I've done transmissions and the rears before. If you can rebuild a motor, you can rebuild a differential. Just get the right tools and the manual. There's an excellent tutorial right here on this forum that was done recently too with lots of photos.
Mrjvieira
