Erickk120
- Joined
- Mar 19, 2018
- Posts
- 384
- Reaction score
- 213
I recently replaced my entire suspension, kept the old hub bearings since those have around 50k miles. now brake related I replaced an old cracked line in the driver side and readjusted the pistons back to their resting place to service the guide pins and lube the hardware brake pads are also in good shape. When set and done I bled that caliper turned the vehicle on and bled again with it on for some reason, and after that, I turned the truck back on and boom, the dreaded service brake system message with the annoying chiming kicked in. I filled the master cylinder full again to no avail. Should I just bleed all 4 corners and see if it goes away or did I get into more than what I was bargaining for? Tried to look for info around but can't seem to find definitive answers, Note I don't have the ABS light on its just the parking red one with the message and chiming, any advice is appreciated as this is driving me nuts. Thanks in advance
