Apple CarPlay Issues
RSN NVSN
Omaha, NE
Good Morning Guys,
I have a 2017 Tahoe Premier and I’m having issues with the Apple CarPlay. When I initially paired my phone with the car it worked fine. Then a couple days ago every time I plug the phone in the car Apple CarPlay won’t come up. The phone is still paired through Bluetooth. I can play music through the speakers. But the CarPlay menu with different icons is not coming up.
Any ideas?
RSN NVSN
RSN NVSN
Omaha, NE
It worked before with Bluetooth on. The Tahoe disconnects the Bluetooth automatically.
Tahoe14
Central Fl
Try unpair the phone and then pair the phone again. Sometimes it helps to reset everything.
RST Dana
OH
Good Morning Guys,
Any ideas?
Disconnect from Bluetooth and reboot the phone.
chicagofan00
Arizona
Have you recently upgraded to iOS 11.4 or 11.4.1? Under the Face ID/Touch ID & Passcode section in settings there is a new option that is enabled by default (USB Accessories). I have read from others that having this enabled has caused some issues with CarPlay connectivity. If you go in and check this setting it will show it's slide to the left for being enabled and slide to the right with the green for disabled...it's a bit counterintuitive from the typical enablement of options in iOS.
RSN NVSN
RSN NVSN
Omaha, NE
I figured out part of the problem. My phone is a iPhone 7 Plus and when it sits on the center part that has wireless charging it does not work. When I have it sitting in the cup holders away from that wireless charging section CarPlay works...kind of.
Now I’m noticing that when I get a call it doesn’t come up on the screen anymore. Let’s say I’m listening to radio and I get a call. I hear the ring through speakers but it doesn’t come up on the screen. During the call screen is black.
Again this was all working before when I initially setup the phone.
RST Dana
OH
Hmm,
It has to be connected to Bluetooth for the phone to ring through the audio system, which it must be if you are not using a cable. I haven’t tried it via cable....yet
My 7 plus will charge in my 16 Tahoe wirelessly and still be connected via Bluetooth.
ylwdogs
