Aftermarket Radio Installation - 2015 Tahoe LS with IO3
JohnC12
JohnC12
Orlando, FL
Hi vballrican,
I just sent you an email.
If I could do it all over again, and had a radio to support engine performance data, I go with the Maestro RR.
All the best to you!
P.S. - The user guide was taken down due to changes to the hosting site - I'll try to get rehosted somewhere else and reposted.
vballrican
Hi vballrican,
John, thanks!! I received it! I'm looking at the Maestro RR with a Pioneer Avic radio... :)
vballrican
UPDATE: Bought an AVIC-5201 NEX with the GM3, the Maestro RR, backup camera adapter... Everything is here except the Maestro. Will also look into speaker upgrades as well before I tackle this project. got a quote for $300 to install it... might consider it since i haven't done audio stuff in over 15yrs.
vballrican
PS: the Maestro is here... working on the wiring harnesses this week. Hopefully i can install over the weekend. :)
mikemcc
I completed the Scosche GM5214SB dash kit install yesterday evening. I am much happier with this look over the Metra dash kit with the blank pocket.
The Scosche kit is very nice! It's made of heavier duty plastic than the Metra - and the clips that hold the top dash trim are metal rather than plastic like on the Metra. When removing the top dash trim last night to upgrade to the Scosche, I broke all three of the plastic clips from the Metra kit - very low quality!
After
Before
I wish I could see the picture, maybe I have to post at least once
Classicimpala
What I did was found the wires for the camera and spliced them into that and it worked perfectly. Ill try to take a picture and post it up.
SunDvl83
Has anyone figured out how to remove the radio on models without a center counsel? Having a hard time removing the lower trim piece right below the AC controls.
zeronightwolf
