Esky Mirrors
tdriver113
Illinois
No pic, here's the part # 23154702. It's not listed in the Tahoe parts list but another post indicated this is the one that works when changing to power fold from regular mirrors.
I've seen an 03 pickup with the powerfold mirrors , and physically the switch looks exactly like a regular power mirror switch. I wonder if it's just the plug from the mirror that folds it in, in other words both switches would be the same internally.
TooMuchTxn
Houston, TX
Wondering if the larger Escalade mirrors will fit and function on a Yukon/Tahoe. I'd like a little more surface area on the rear view mirrors. Thoughts? Anyone venture down that road yet?
Just an FYI if anyone is following this thread I started another and completed the escalade mirror upgrade over here.
tdriver113
Illinois
Installed the mirrors and switch. Had to use the 23488411 switch listed in the Tahoe parts list. The 23154702 switch listed in another post did not match the harness plug. Mirrors adjust up and down and side to side ok. Drivers side folds, passenger does not. Also when using the exit button, both mirrors move to show the tilt in reverse setting.
Will do some troubleshooting this weekend to sort things out.
FYI : 2016 Tahoe LT with standard mirrors.
Art Contoni
Central, IL
Just to keep the info in the same type thread - I installed the Esky Mirrors in a 2017 GMC Yukon SLE (w/o A45 Memory) this weekend. Puddle and Turn Signals worked Plug n Play but I need the DL3 used switch: 23154702 or 84643953. The 23488411 switch I bought was not the same connector plug key as my factory harness. I have a thread going here: 2017 Yukon SLE DL8 to DL3 (w/o A45 Memory) So I'm looking for a DL3 used switch: 23154702 or 84643953.
Juju14
