Help! - '05 Yukon Gas Leak
TMXX1
I noticed a gas smell a few days ago and thought nothing of it. But today, it's much more. Major gas leak.
Laying under the car, I can see it coming down the side of the tank, exactly in-line where the driver door and the back door meet. I can't tell if it starts from the side of the tank, or the top. Not sure where makes more sense.
How do I go about figuring out what this is, and how do I fix it?
Thank you so much guys.
Chip18
Dayton NV
That sounds like a "don't be driving" until this issue is solved!! First step would be a fuel pressure tester and a "Fire Extinguisher" since you have a know leak.
You can rent a fuel pressure tester from an autostore, I don't know what the fuel pressure should be on these guys?? But someone here does. And you can add this if you can't find the leak with that tool alone.
https://www.amazon.com/Mastercool-53351-B-Professional-Detector-Light/dp/B000IHJXHG
nharkey85
Alabama
My guess would be a bad line or connection on top of the tank. If it were the tank itself it should only leak when fuel level is above the source hole/crack/etc
T
TMXX1
Thanks Chip
On the last drive I took with it (while leaking), it leaked the most at 2 points, during turns, and when I put the car in park. On the staightaways, next to nothing (I looked at my road and inspected), does this point to anything specific?
T
TMXX1
How do I go about figuring this out?
T
TMXX1
Just did some exploring under the truck...right where that support that holds up the tank goes (right in line with where the doors meet), on the top of the tank there feels like a indent there, it feels like a baseball size, and it's full of gas. It's definitely an indent that it meant to be there, but the gas is not.
...Am I really dropping the tank next? Gonna be a crappy night...
nharkey85
Alabama
I've never had to deal with anything back there, but I'm assuming there's not enough room to do any real work without dropping it
T
TMXX1
It actually looks like it's in the front of the tank...towards the front of the car. Does this help?
I'm trying to find a diagram of the tank or something, but no luck yet
Chip18
Dayton NV
I've seen at least one thread here regarding corroded fittings at the fuel lines on the top of the tank. You can do a search here for others that have had the problem or just go ahead and drop the tank since there's probably nothing you can do to fix it unless you do.
Edit: that link shows the same as what I saw here on this forum. No need to go search! So yeah, those fittings.
Chip18
Dayton NV
Wait ... what ... fuel??? I was looking at the pictures of the link I posted and that was a horror show!!
It looks like because of the design of the fuel tank ... water/snow and crap could get trapped up there?? if it did the fuel lines could be easily damaged ie rust?? Guess it does not happen enough for GM to change the design??
So it seems that more than likely ... your gonna need to drop the tank ... hope it's not full of fuel???
Chip18
Dayton NV
LOL ... you've been here longer, these beast are new to lots of us. :)
Sounds like what I had, ended up the whole sending unit was rotted out. Just bought a new pump and sending unit to be safe.
Also there is absolutely no way to dont wi Bout dropping tank, you can drop it a little bit to see what's wrong, but if it is rotted out, I wouldn't drop it until you are where it needs to be, last thing you need is to try dropping it and break any rotted lines. Been there.
Woned2004
