this thread is just a reference for whoever needs help with head unit/external hard drive connection===i installed a pioneer avh-p5100dvd a while ago. the unit has a usb connection which i use an external hard drive (HD) filled with music. the HD is a 40 gig which comes in a format that doesnt work on the head unit. (i forget which format) anyway in order for me to use it with the unit i had to shrink the HD to 16gig and then reformat it to fat32. if your pc allows it you can shrink it to 32gig but no higher. the head unit came with a usb extension so you can mount the HD outside the dash. some may have trouble powering the HD through the unit and have opted to use another power supply, others have found that connecting the HD directly to the head unit using only one usb cable(skipping the ext. cable) gives sufficient power. i myself discovered that using a bigger gauge cable works great. i recently tested a 26gauge usb cable which is normally used to connect my superchips flaspaq programmer to my pc. it now powers the HD great and allows it to play instantly as a regular cd would. i may just decide to connect the 26 gauge cable directly to the unit for even more power, ahh! ahh! ahh!=====anyways, i hope this could be helpful to others, thanks for reading!
aka
(((snap)))
aka
(((snap)))
