Z06 brake conversion
Chiggy
Kansas City, MO
That's probably not worth the thousands of dollars it's going to cost. Most just upgrade to 07+ Tahoe rotors, calipers, and brackets.
ivin74
ivin74
05 NBS Nali
Htown, Texas
Chiggy, what the difference on the brake rotors between an 05 tahoe and 07 ?
fiatdale
Houstons Best
Houston
I was about to., then I decided on the wilwoods kit. I still have the brackets for the conversion if you want them.
01Konvict
Boats n Hoes
Raleigh/SML
The 00-06 have 12" rotors and 07-13 have 13" rotors but the upgrade also has a redesigned caliper
Chiggy
Kansas City, MO
Yeah that. I did it myself. I got reman calipers and brackets from the parts store. Ordered a stoptech slotted and drilled rotor and pad set and Russel Stainless lines. Stops so good now. Next I'm going to flush the PS pump for my hydroboost to have some fresh fluid. It helps a little with pedal feel
davzava
Would this mod work for OBS Denali? I have the silly drum setup on her still.
Edit: The NNBS rear disc brakes I meant.
