What is this part called?
JonathanCR
I have a 2009 GMC Yukon XL that suddenly got a rattle that sounded like pocket change near the driver side wheel. After inspecting, i think I found the issue, but I'm not sure what the part is called to order a new one. See image - you can one of the rubber brushings has rotted out and caused the plastic middle piece to rattle up and down. What is this part called?
HiHoeSilver
Away!
Chicago
I have a 2009 GMC Yukon XL that suddenly got a rattle that sounded like pocket change near the driver side wheel. After inspecting, i think I found the issue, but I'm not sure what the part is called to order a new one. See image - you can see one of the rubber brushings has rotted out and caused the plastic middle piece to rattle up and down. What is this part called?
Looks like your stabilizer link. Aka sway bar end link. You will find it on Rock auto under suspension.
Buy the Moog Problem Solver one. It's like $9.00
Also, there's a code for 5% off in the vendor section of the forum.
DefiantOne
