Weird Voltage reading
AngelXL
Guys I need your quick...
So I left NY yesterday and I'm in Orlando now.
On the way here and as I'm typing this thread. My voltage shows very low.
Only difference we have done is the demand on all the phone, laptop and IPad hook up to the ports.
Is this normal?
If I turn off the truck and restart it goes back to normal.
The other thing is we have driving the truck nonstop for 18 hours.
Kenny D
Crosby, Tx
Probably the "fuel saving" mode of the charging system. The NNBS has it too.
AngelXL
AngelXL
Thank you thank you.
I was so worry... I still gotta drive down to Key west.
Miami-Dade
Super Moderator
Drove down to Key West a couple of months ago. A lot of Leos were out on US 1..FHP and Monroe Sheriff were all over the place.
AngelXL
AngelXL
I had been pretty good with the speed limit. Taking advantage on the 75 mph
AngelXL
AngelXL
It was like 104 degrees. Crazy!​
PG01
Up here to the right
Anywhere in that range from 14 is normal. that horizontal white line that goes thru 14 to the two verticle lines say at 13-15 but prob more 12-16 is all normal.... def rvc.... alt shuts off and turns back on when batt falls below 12v-ish or so. Tow/haul made is supposed to turn that off so it should read in the midd somewhere and some other combinations turn RVC off also
TahoeOn30s
Is this normal?
totally normal I have 4 alternators and 6 batts and my truck does the same bs...damn fuel economy modes
Bryndan99
