Intenseman
- Joined
- Jan 30, 2017
- Posts
- 11
- Reaction score
- 0
I have a 95 GMC Yukon. I've noticed puddles under the left or right side, depending on the slant of the ground where the vehicle is sitting. The leak is coming from the washer fluid, but not from the tank or any hoses. There isn't any fluid on the fender well where the tank is mounted. The fluid is actually under the cowl and dripping down either side on to the ground. The end of the sprayers are damp. By the way, this is without using the washers at all. Just getting in and driving it and showing up to work, parking the vehicle, and noticing the drip.
I'm thinking this may be a leak of low voltage into the pump causing it to just run very slowly and push out just a little bit of fluid at a time.. I'm not sure if that's possible but it's the only thing I can conjure up. The puddle area is large. And there isn't any drips leading up to where I stopped. So I'm thinking this is happening after the vehicle is shut off.
For different reasons, recently I have replaced the pump and the pulse board.
Thanks. Any help is greatly appreciated.
Michael
Michael
