Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I pulled my drive shaft the other day and noticed that the splined rear output shaft on my transfer case moves in and out a little, about 5/32 of an inch. I take it as normal end play...... anyone else experience this?
Is it literally moving in and out or side to side? The rear output shaft is supported by a needle bearing and this bearing typically dies a miserable death after a long time of high pitched whining when the transfer case has been ran low on fluid.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
