As far as I know... AC DELCO AUTOTRAK II is the right stuff for your Transfer Case.... IF you have a NV 246
Case...
If you have the switch on your dashboard that shows... 2WD 4WD AUTO 4 HI 4 LOW then you should have a NV 246 TC... you can also crawl under your ride....and take a close look ...there is a metal shield on the TC that tells you the NUmber.
hope that helps
Greetings Juergen
...forgot something you need 3 bottles ! because the "earlier " TC case need a little more than 2 quarts..
