All that is doing is assuming load is a linear relationship with pressure, and then dividing evenly amongst the tires which doesn't take into account the rear tires need more pressure when loaded.
Proper way is to look up the TRA load vs inflation tables for your tire size, then use GAWR divide by two for each axle.
As mentioned in my particular post, the inflation tables were incomplete at 5 psi increments and not linear but graphing them out on Excel helped fill in the blanks.
i dont do math, i read the sidewall of the tires and add air.
Scotty, you're a smart guy but need to some tire learnin' my friend! Listen to the fellas here.
