SlimJim
- Joined
- Mar 7, 2016
- Posts
- 41
- Reaction score
- 5
So i got fed up with trying to find a definitive answer of what PSI i should run my tires. Everybody just says use the door placard but that doesn't work when you've changed tire and wheel size. So instead of doing a trail and error or best guessitame i went ahead and found a local tire guru at 208 TIRE here in my town. This is how he broke it down for me on my tahoe, but it can be used for anybody changing tire sizes.
Im running 33x12.50r18 Atturro M/Ts with Moto Metal 970s
EXAMPLE:
MAX TIRE LOAD= 2910 pounds
MAX TIRE psi= 65 psi
GAWR Front & Rear (vehicle weight front and rear, found on door placard)
FRONT=3600
REAR= 4000
So you take your tires MAX TIRE LOAD and divide it by the tires MAX PSI
2910/65=44.7 rounded up to 45
Then you add the GAWRs together
3600+4000=7600
Then you take the combined weight and divide by 4 (this gives you the weight each tire must support)
7600/4=1900
Next you take the answer for that and divide by the PSI you found for the first equation
1900/45= 42.2 and round it how ever you like.
The final equation gives you the psi your should be running in each of your tires. This equation take into consideration the weight of you vehicle and the max load each tire can support and disperses the weight evenly per tire. i have been running this psi in my tires and have had great results (optimal fuel mileage and wear).Hope this helps someone.
EXAMPLE:
FRONT=3600
REAR= 4000
3600+4000=7600
7600/4=1900
