Every things is OEM no any modificationNot normal. Is your setup stock or aftermarket?
The dealer inform me that he will replace the upper and lower arm with 2016 model is that enoughNot enough backspacing on the 20" rims...
You likely need a different wheel/tire setup to prevent rubbing like that unless there is something wrong with your steering.
