I need advise. My rear stabilizer bar keep wiggling loose. So I have a eibach sway bar lowered 2/4. My bar is moved over but on the drivers side i haven't had success with a nut bolt combination that won't wiggle loose. The passenger side was stripped from the chassis so I had to do the nut bolt thing there also. I can get it snug and good for like 50 miles then it pulls so ******* the chassis it tries to loosen and I get a popping noise. The bolts have to be short because of clearance and when tight the bar is being gripped by the bushings so tight it doesn't move up and down well and puts strain on the rear end plates.
Wondering what you all have used.
Sent from my iPad using Tapatalk Pro
