reedal
I have a pair of used HAT L1pro tweeters for sale. I bought them used, haven't used them, I want to step down to the L1v2's which will fit my current needs better, as they're slightly smaller. Both read 3.6ohm, which is exactly what the spec sheet in one of the attached pictures says the DC Resistance is supposed to be. The threads and mounting rings do show some signs of use, where the color has rubbed away. On one of the tweeters, there is a clear bead of glue around the bottom of the aluminum housing (pictured) from the last owner separating the protective housing from the rest of the tweet. It still works as designed, it's simply a cosmetic issue.
I would like to sell these for $350, but I will entertain all offers. No trades. Thank you.
