My '07 Yukon has been vibrating considerably lately and I'm not sure where to start. The problem is mostly while cruising when the truck slows down and tries to downshift it will shudder.
I took my truck to several shops and had different reasonings.
1st Shop gave it a maintenance tune up but the vibrating continued and mentioned it was the motor mounts.
2nd Shop changed my differential fluid and checked the gears but the vibrating continued and said it was the tranny mount.
3rd Shop changed the driveshaft u-joints and mentioned all mounts are okay and suggested I just drive it until the transmission gives out.
I was doing just that until last night I was driving around 80mph when I noticed a similar type of shudder that started happening that didn't stop, even in park, until the following day.
I checked online and a 2013 post mentioned to put it in neutral to see if it stopped, which it did, thus probably being the torque converter. The thread then drifted to mentioning that the Ranger Afm disabler probably fixes the problem.
Anyone with a similar experience know where to start?
