TheAutumnWind
- Joined
- Jan 8, 2015
- Posts
- 3,222
- Reaction score
- 1,919
I did the steering too- Pitman arm, tie rod ends, idler arm, idler arm bracket. Also upgraded the swaybar and end links and associated bushings. There's not much else to do after that. Mine was at 145k and I'd think you're due for steering components too; might as well get it all done at once, get it aligned once and be done with it. I also added a steering stabilizer at the same time, a KYB that was only about $45. Night and day difference after all that.
If you are doing all that then you might as well replace upper and lower control arms too.
