TURNz
- Joined
- Jan 30, 2012
- Posts
- 168
- Reaction score
- 27
On the radiator, under the upper coolant hose, there are two fittings. One all the way at the bottom and one just under the upper hose.
I believe it's the transmission lines. The fitting screws into a larger fitting that is like a hexagon made from bent sheet metal.
The upper sheetmetal fitting keeps backing out a little and causing a leak. I tighten it and it does it again a couple weeks later.
I'm thinking about wire tying it to the shroud. I'm not sure how else to keep it tight.
