Been trying to find the balance between comfort and proper wear and proper load carrying capacity of the truck's new tires. They are BFG KO2s LT265/70/17 Load Range C.
The door placard says 30 psi all around for the original Goodyear Wrangler HPs which are P-Metric tires.
The maximum weight for the Wrangler tire is 2,535 lbs @ 35 psi. At 30 psi this number is 2,348 lbs. But that is too high when mounted on a truck/suv. The standard is to then divide by 1.1 so this puts the tires at 2,135 lbs @ 30 psi giving them a combined carrying capacity of 8,538 pounds. The truck's GVWR is 7,400 lbs so the tires can support a little more than 1,100 pounds extra weight when properly inflated.
Whew!
The BFGs are rated for 2,470 lbs @ 50 psi. Their tire inflation and load chart only specifies ratings in 5 psi increments so I had to subtract the difference and divide by 5 to fill in the missing numbers.
For example, at 50 psi the tires are rated for 2,470 and at 45 psi they are rated for 2,255 pounds. The difference is 215 lbs and divided by 5 that is 43 pounds per psi. Curiously from 40 to 45 psi the factor is 36 pounds and from 35 to 40 it is 37 pounds. Does that make sense and am I figuring this right?
Well, if I am indeed correct, 42 psi provides 2,147 lbs per tire or 8,588 pounds for all four. That's as close as I can figure to the originals. Now tomorrow I plan to check my tread depths across each tire and if I can find the chalk, do the chalk test with the tires set at 42 psi.
I've been running them much lower, just completed a 1,200 mile trip with them at 38 psi and currently they are at 44 psi cold. The ride real nice at 30 psi, 44 is quite bumpy.
Comments or suggestions?
Whew!
